Christopera
2013 Sportwagen. Like the title says, I get in the car yesterday, no rear wiper, no sprayers front or rear. Front wipers work on all settings. Front wipers will run after attempting to spray, but nothing ever sprays.
Has to be the stock right? I went through all the fuses (I can't find a fuse diagram anywhere, so frustrating) and everything looks fine. There's was a tad bit of corrosion on some of the in-cabin fuses, I cleaned them up and put them back. I did all the fuses one by one, because how would I know where they go without a fricking diagram.
Car is still under 2 year warranty, is this covered? My father has VCDS, so I will probably borrow that and see if I can test further.
