emissions system
milesjettaboy
Bridgeport, NE
2009 Jetta TDI 6spd manual
After searching and coming up rather empty handed, I figured I'd start a thread. On the newer tdi's they implement a def system to aid in reducing the amount of egr usage correct? If that's the case, could that be retrofitted onto the 09's somehow? Thanks in advance.
740GLE
NH
The passats are using VW's CR version 2, and are getting slight better MPGs. The engine code is different, as well as the emissions system. I think it'd take quite a bit to get the two systems to blend.
with the time and cost, a DPF delete would be the best investment, maybe not so for the environment though.
