TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   Other VW Group TD(I)s (http://forums.tdiclub.com/forumdisplay.php?f=41)
-   -   Audi A4 CGLC limp mode (http://forums.tdiclub.com/showthread.php?t=503953)
carsey December 8th, 2019 09:42
Hi all
Just had a fault crop up on my 2012 A4 CGLC Quattro where it drops into limp mode and throws the ESC Light on with a flashing Glow plug light.
Plugged it in when I got home and seen there was a few fault codes on the Sensor Reference Voltage B - Open Circuit.
When the fault comes on, either running or sat with ignition on, the revs increase to 1000rpm over standard 750rpm and the lights mentioned above illuminate. Theres also a change in engine note and engine is pretty shuddery when stopping. Upon restarting, it can often turn over a couple turns rather than firing up straight away.
Only things done to the car is a ECU remap and a EGR blank (remapped due to EGR throwing codes up causing limp about 2 years ago and been perfect since)
Ive included a full VCDS scan below for reference.
Any help appreciated.
Chris
Sunday,08,December,2019,15:50:50:09611
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 19.6.1.0
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8K9Dxxxxx License Plate: CHSSCFULL
Mileage: 103950km-64591mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K9DA01xxxxx Mileage: 103950km-64591miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JH HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2903
Revision: 45H25---
Coding: 0A194012242601080000
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JH 003003
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 79F303EDF8FCD987DE-802C
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 103925 km
Date: 2019.12.08
Time: 13:20:13
Engine speed: 1778.50 /min
Normed load value: 5.5 %
Vehicle speed: 90 km/h
Coolant temperature: 85 C
Intake air temperature: 12 C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.700 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 232
Cruise control switch-off: irreversible-Bits 0-7: 4
Cruise control switch-off: reversible-Bits 0-7: 15
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 16
4124 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 103925 km
Date: 2019.12.08
Time: 13:20:12
Engine speed: 1745.00 /min
Normed load value: 60.8 %
Exh.gas temp.sen 1: 485.0 C
Exh.gas temp.sen 2: -0.0 C
Exh.gas temp.sen 3: 342.2 C
Exh.gas temp.sen 4: 287.6 C
Shut-off timer: last engine shut-off time: 719 s
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 181544
Shop #: WSC 06325 000 00000
VCID: 030F61058230935784-8056
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 FE HW: 8K0 907 064 FE
Component: BCM2 2.0 H10 0602
Revision: 00002001
Coding: 03B10000000000000000
VCID: 78F506E9CBF6C08FA1-802C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0812000007530014
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000002761004
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 234
Mileage: 102524 km
Time Indication: 0
Date: 2019.10.06
Time: 09:57:04
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC
Component: KLIMA 3 ZONEN H04 0122
Revision: D0000000 Serial number: 01310120121717
Coding: 342402E000
VCID: 6AD12CA1855A621F27-803E
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 14
Reset counter: 3
Mileage: 103925 km
Time Indication: 0
Date: 2019.12.08
Time: 13:20:13
Freeze Frame:
Temperature: 7.0C
RPM: 1800 /min
Speed: 90.0 km/h
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 AG
Component: BCM1 1.0 H14 0103
Revision: 07014001 Serial number: 00000025901802
Coding: 260000118034AFC00081400000001D0D401D03082709020100 0008000400030100000024000000
Shop #: WSC 00783 210 84012
VCID: 77F705D5C6E8CFF7A8-8022
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250112 H06 0070
Serial number: SWF12010250214
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0001
Serial number: 20131050
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001901123251
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 87488C06000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD90MJ6L
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 63301 000 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4895B629F396700F11-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME6A12397DO
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME6A133544A
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME56693146H
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME0B6A124CO
Crash sensor for front airbag: driver side:
Serial number: 63732SME17683C50+
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME17683376+
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120130001213
Coding: 000016
VCID: 4FA79D351EF8A73750-801A
Component: E221 - MFL H03 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 B HW: 8K0 920 982 B
Component: KOMBIINSTR. H16 0640
Revision: 00100000 Serial number: M3B32GNDC
Coding: 331D090002012600010001
Shop #: WSC 06325 123 12345
VCID: 336FF1C59210E3D754-8066
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 A HW: 8R0 907 468 A
Component: GW-BEM 5CAN H10 0025
Revision: 1V040013 Serial number: 1341V12118863C
Coding: 00CF07FF00
VCID: 3D7BD7FDA45425A7B2-8068
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7388956501
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12029000864021200410
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 252
Mileage: 103355 km
Time Indication: 0
Date: 2019.11.29
Time: 14:18:06
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.20 V
Count: 6
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 3973C3EDB07C19879E-806C
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 F HW: 8T0 959 793 H
Component: TSG FA H09 0302
Coding: 011002204001410001
VCID: 4C9D8A39EFEE9C2F35-8018
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0021322952
Coding: 100000000001
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 346DF2D99F1EE4EF4D-8060
3 Faults Found:
16400 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 244
Mileage: 102164 km
Date: 2019.09.04
Time: 17:22:10
Write only channel
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 244
Mileage: 102164 km
Date: 2019.09.04
Time: 17:22:09
Write only channel
2306 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 3
Mileage: 103370 km
Date: 2019.12.02
Time: 12:10:15
Write only channel
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0168526440
Coding: 011F062200B900408020013680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T1 035 223 HW: 8T1 035 223
Component: DSP Prem H04 0040
Revision: 00004001 Serial number: 94804001211301
Coding: 0203010302
VCID: 6CDD2AB98FAE7C2F55-8038
1 Fault Found:
02247 - Subwoofer (R148/R157)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 9
Mileage: 91922 km
Time Indication: 0
Date: 2018.09.18
Time: 14:17:06
Freeze Frame:
Voltage: 12.70 V
Temperature: 38.0C
Temperature: 39.0C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 H HW: 8T0 959 792 H
Component: TSG BF H08 0302
Coding: 011002204C01410001
VCID: 4D9B873D14F4952722-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 00000000017259
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 3669C8D18962F6FF73-8062
3 Faults Found:
721152 - Brake Pad Replacement Mode Active
C1011 00 [000] - -
464128 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 218
Mileage: 103925 km
Date: 2019.12.08
Time: 13:20:13
Voltage terminal 30: 14.9 V
Internal Fault ID: 187
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Dynamic
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 103950 km
Date: 2019.12.08
Time: 15:47:40
Voltage terminal 30: 11.8 V
Internal Fault ID: 188
Vehicle speed: 0 km/h
Function light in parking brake button: On
Red operating lamp: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: static
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R2 035 186 A HW: 8R2 035 186 A
Component: Concert3 DAB H05 0440
Revision: 00000005 Serial number: AUZ5Z6L1694807
Coding: 0403008201018D00875B070800
VCID: 346DF2D9971EE4EF4D-8060
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 40
Reset counter: 252
Mileage: 99435 km
Time Indication: 0
Date: 2019.04.06
Time: 13:13:59
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 H HW: 8T0 959 795 H
Component: TSG HL H07 0302
Coding: 010002204001210001
VCID: 50A59E4903C6B8CF49-8004
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0302
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005465496
Coding: 0010320
VCID: 3D7BD7FD645425A7B2-8068
End-------------------------(Elapsed Time: 03:45)--------------------------
Page generated in 0.06931 seconds with 8 queries
[Output: 29.36 Kb. compressed to 24.77 Kb. by saving 4.59 Kb. (15.65%)]
