06 Jetta TDI clutch master cylinder
Zxd5298
Red bluff
06 jetta brm
Guys,
I have an 06 tdi I broke the connector on the clutch master cylinder and I’ll call Renard start obviously does anyone know where I can find a new connector or if there’s a way around it?
tactdi
North Carolina
2005.5 Jetta
Check the pick a part yards in your area for Jetta's.
You can pull the clutch master without too much trouble and then pull the
sensor off the master, and cut the wire connector going to the harness.
You will need one of those pin extractor tools (FLAPS usually have them), to
replace the wire connector (if that is what needs replacing).
jetta 97
Dallas (McKinney) ,TX ,USA
2 X Jatta MK5 2006
VW Dealer sells all connectors, On old connect you can look part number .
They are not expensive , I would say around $10.But like mention above you will need tool to pull wires off .
