mjhandy
I've always wondered why not a chain driven system rather than a belt? Wouldn't a chain last longer?
__. Talk about comparing apples to oranges! The old MB's are big, slow-turning engines with compact timng system layouts. Chains are imprecise and don't like revs. A chain on a TDI would be whipped to a frazzle. A chain would be a bad choice for a TDI, as much as for the imprecision of the timing as anything else. A few degrees on a TDI and valves are intimately associated with pistons and that means a head rebuild 99% of the time. Chains "stretch" and have imprecise tensioning systems. Chains would not be good on a TDI. The belt is about as good a system as you'll get.oldiesel said:Actually the chain in my 300d 2.5 Mercedes was much easier to replace and also less expensive than the belt and related hardware on my Jetta and the Jetta is the easiest of the TDIs as it is an AHU.The Mercedes had over 240,000 miles when i did it just as a precaution as it was showing more than 5deg of wear.Sort of comparing apples and watermelon as there is such a great difference in the price these cars were built to, i guess MB could afford to build a longer lasting system. Don
__. But don't you unnerstann? Mah gran-daddy had a flathead Ford peekup truck - changed the awl ever 1000 mahls with 99 cent a quart awl fum the Wawmott and thet truck ran over 200,000 mahls. An it hed a tahmin chain. Whutt's gudd enuff fer that truck oughtta be gudd enuff fer them flimsy little furrin thangs!TDICADDGUY said:Ahh crap not this again.
This has been discussed before, many times. (snip)
really? ever hear of the v10tdi?Velocity1896 said:I wouldn't take either, I prefer gear drive. Even though its would never happen in TDIs. ...
You talking about the primary drive or the drive to the back wheel?weedeater said:I always ask myself this question whenever I see a Harley go by with a belt rather than a chain.
You must not work on cars for a living.... TDI timing belts are EASY compared to a number of cars out there... Ever mess with the chains on a ford OHC explorer? THAT takes all day.. How about a "simple" valve cover gasket on a 4.2 trailblazer? hehe.. give me the TDI's.. they are simple and easy..need4speed said:belt, chain, I don't care. Just engineer the damn thing so it doesn't take all day, special tools, and a computer timing job to replace it. Pain in the keister.
what is your point of reference for simplicity? i guess it is complex next to a carburated push-rod engine.need4speed said:belt, chain, I don't care. Just engineer the damn thing so it doesn't take all day, special tools, and a computer timing job to replace it. Pain in the keister.
All day? It can be done in 3 hours if you have the proper tools. And if you are good, no need to mess with the fine tune on the IP.need4speed said:belt, chain, I don't care. Just engineer the damn thing so it doesn't take all day, special tools, and a computer timing job to replace it. Pain in the keister.
I agree. I had a 93 MB 300E and that cover was a pain to keep leak free. The timing belt system is much easier to deal with IMO.Keith_J said:Chains require lubrication. Which would make the front covers much more complex as well as have a drain back to the crankcase. Another point for oil leaks? And that would be a difficult job to fit it all in. And then the water pump? That weep hole would now communicate with the crankcase so instead of a coolant leak, you would have to flush the oil system. If caught early enough.
Sorry, I have to jump in... V4 Saab engine? What year? Model? Availability of parts?Lug_Nut said:Gears are heavy and their rotational inertia adds to the same apparent power loss as a heavy flywheel or larger brakes or larger tire and wheel sets.
Yeah, I have a geared cam drive on my 1.5 liter V4 Saab. A big slow revving class 8 OTR truck won't mind the extra spinning mass, but a 2 liter definitely does.
