TDIClub Forums
TDIClub Forums (
-   TDI 101 (
-   -   2002 Jetta TDI 01M transmission replacement options (
Lancelot1953 October 6th, 2017 15:32
Good evening, first tread newbie to the TDI Forum, please be gentle (and patient),
Problem: 2002 Jetta TDI 224,000 miles with 01M transmission which I have nurtured and eventually "locked" after slipping/difficulty engaging in Reverse, 1st & 2nd gear for the last 30,000 miles when it was diagnosed as "finished" by the dealership.
Background: I am a Disabled Veteran with a damaged left leg (getting worse) which has confined me to using automatic transmission. Sadly enough using a 5-speed conversion or my other 2001 manual TDI is no longer an option for me. I have read many forum comments/threads recommending the above and I am a bit confused. I do most of my own maintenance.
Question: I would like to use a rebuilt transmission and preserve my car.
- Is there a different (used/rebuilt) transmission such as a 5-speed automatic that would be retrofitted in my TDI?
- If a professionally rebuilt 01M is the only solution, what/who would the TDI Club experts recommend? I read some good comments about IPT Performance Transmissions in NJ. Anyone else? I can drop the car off within 800 miles from Portland, ME, family helping.
I would appreciate any advice, thank you, Ciao, L
PS: I am very kind if not obsessive/compulsive caring for my vehicles (still have my first car circa 1970) so a bullet/idiot-proof transmission is not a requirement for me.
ketchupshirt88 October 6th, 2017 16:12
coolairvw is the expert on here if you wanna look up everything there is to know about the 01M.
a good used trans is the cheapest option and they do come up for sale often enough by ppl doing 5 speed swaps as a preventative matter. rebuilds are considered hit or miss... unless you spend like 4K to get it straight from VW...
the next newer trans on the 2004+ jettas isnt compatible to swap into a 2002
Rrusse11 October 6th, 2017 17:20
Start here Lancelot;
Lots of information on the 01M, and from all
reports, they can actually fix them! I sold mine for a song after my swap to a 5 speed. They do pop up in the classifieds.
If you find a used one, a fluid/filter change and adding a cooler can keep them going sometimes. I found putting mine in "touring" (something like that, instead of "adaptive") mode with VCDS, and then manually shifting it made a real difference.
aja8888 October 6th, 2017 19:06
First of all, thanks for your service. :)
As said above, give the guy in KC a call. Maybe he can source you a good condition used 01m. Installing a later (Pump Duse engine) automatic like the 09a Asian trans is not an option without a lot of headaches.
flee October 7th, 2017 11:21
We have an 02 w/ the 01m which is on it's second life after a rebuild. It is doable.
Only use a local shop with experience doing these and a 2-year/ 24k mile warranty.
We have made considerable use of the warranty since the rebuild and made sure
they 'reset' it each time it went back. It's working pretty well now for 12k miles.
VLS_GUY October 7th, 2017 11:43
Firstly, If you can get another car with a ore reliable automatic transmission do so. The 01m no matter who manufactures it will never be reliable. I have had the common failure points mitigated and then the transmission failed due to the differential failing and breaking the transmission case- end of the road.
Autobahn in Reading, PA does rebuild this things for around $ 2,100.00. But be prepared to go back a few times to fix things that break under warranty:
Next don't take your car to the dealer. I would use Herm in Richmond:
jasonTDI October 7th, 2017 12:03
These are actually VERY reliable if the fluid/filter is changed OFTEN. I service many on their first trans with 300K plus on them. While they don't always shift perfectly they have proven to be more reliable than a lot of other autoboxes in the industry.
All related to an aforementioned trans shop is now removed due to issues with several of their transmissions. Not a happy camper now.
VLS_GUY October 7th, 2017 13:19
Yes I was ttalking about Dubble's. They do a good job on the 01M given its structural and design limitations.
I know of at least 3 01M transmissions that were serviced regularly that failed via broken internal seals, bad differentials cracking the case, or pressure loss that could not be isolated with out a proper test stand.
I also know that Jason sells the transmission from 5 speed swaps to Dubble's as cores so is very familar with them. The remanufacturing of the 01M may be nearing an end due to no new supply of Planetary Gear Sets. If you have source of them Dubble's would want to talk to you. Her is their link:
I would suggest you talk to Herm and see if he would install their reman 01M if you want to go this route. The kit the send is complete and easy for an experienced VW mechanic to do.
UhOh October 7th, 2017 13:39
I always see low-mileage 01m cars for sale. I can only imagine that there's also a representative amount to be found in wrecking yards. How low is low enough? No idea.
At about 170k miles I had the valve body replaced (with one from CoolAirVW) and the fluid changed. Someone in the past had done some transmission work on the car (got it with about 165k miles), but no idea what that was. The trans triggered a "bad" code, twice, and while it was quite a while between codes I decided to be proactive. Time will tell whether what I had done will be cost effective or not. Car belongs to the daughter and is operated in a big metropolitan area, a manual trans is out of the question. I figure it all cost-averaging: car was fairly cheap; I've got it fully maintained now, better than any other used car, if the trans can do a couple of years I figure it's money well-spent.
If only there was a way to figure out why certain 01m transmissions defy most odds I'd think that there could be a pretty sizable resurgence in these cars. Of course, all of our other cars (four others) are manuals (one being an 02m).
VLS_GUY October 7th, 2017 17:33
In my limited experience in Southern California operating in a hot area with lots of high speed highway travel is a certain way to lower the life of a 01M. This is why I like to change the transmission fluid every couple of years with improved fluid. I don't want to operate with cooked transmission fluid given the material (valve bodies, seals etc.) and design choices (differential housing, fluid flow) VW made on this thing.
One thing to remember: Change the differential fluid on your 01M. It is frequently over looked, a failed differential will often break the case, rendering the transmission unusable as a remanufacture core.
UhOh October 8th, 2017 08:31
Great point to note the diff fluiid. I made sure to change that in the daughter's wagon.
mrseadog October 8th, 2017 10:35
I have used Dubbles twice ( I have 2, 02 TDI's) and would probably use them again is the need arose. Both transmissions were replaced in the 220,000-240,000 mile range. One car now has about 270,000 on it and the other 295,000.
The wife does not do manual transmissions so there is zero chance of ever going that route.
Lancelot1953 October 12th, 2017 14:41
Thank you for the valuable advice
I would like to thank the members of the club for their valuable advice - I will follow your recommendation(s) and call these references to find a suitable replacement and/or rebuild.
I really appreciate also that no one "shot at me" especially after asking a question on a topic that has been beaten to death in the forum... since being a Veteran, I am kind of "sensitive" to being shot at physically or ...verbally.
Thank you again to the TDIClub community.
May Peace be with you all, Ciao, L
PS: If anyone needs to protect their prize TDI against air attacks, I have some experience in the matter and can help you establish an effective defense perimeter or BARCAP ;)
BobnOH October 12th, 2017 15:16
Don't sweat the perceived negative comments, people have different perspectives and you'll find most everyone here just tries to help. It is the internet.
As was said, a low mileage unit from the salvage yard is the least expensive option. Rebuild you want to check out the rebuilder.
Being ignorant in these matters, I wouldn't rule out a new one. If anyone has any, what are they going to do with 'em?
Lancelot1953 October 12th, 2017 18:43
Hi BobnOH,
Thank you for the advice (and reassurance), it makes a lot of sense.
I will keep the club informed of my progress,
Ciao, L
Page generated in 0.07226 seconds with 8 queries
[Output: 18.99 Kb. compressed to 18.35 Kb. by saving 0.64 Kb. (3.35%)]
