TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   VW MKIV-A4 TDIs (VE and PD) (http://forums.tdiclub.com/forumdisplay.php?f=12)
-   -   What did you do to your MKIV today? (http://forums.tdiclub.com/showthread.php?t=452221)
sriracha June 18th, 2019 12:18
Originally Posted by Judson (Post 5516422)
Would you mind please posting a "before" pick? For some odd reason, I can't imagine what the difference is between the new and the old.
Thank you very much.
I was too excited to begin the process and forgot to take pictures immediately before starting, but here is a before picture:
http://pics.tdiclub.com/data/500/med...6F58BA39F.jpeg
After:
http://pics.tdiclub.com/data/500/med...D7E33782F.jpeg
I haven't tested the lights at night yet, but aesthetically, they look great. Plus, I installed all new plastic grill items on the lower bumper. The front end looks new!
Maybe it's a placebo affect, but the wagon feels more stable with the 4-Motion valance, at highway speed. The shape of the original valance would promote lift, while the 4-Motion valance is flat and cuts the air upward towards the radiator. Compared to the original valance shape, there has to be less promotion of lift at highway speed. Am I imagining things?
Wigstdi June 18th, 2019 13:59
First launch on the 215/70/15 lift and gtb1756vk and wow still smokes them right off. Poor Audi to never saw that coming :)
flee June 18th, 2019 14:09
After:
At highway speeds, yes.
The difference in forces at 65 mph is probably about equal to what you ate for lunch.
dtwbrowne June 18th, 2019 14:54
Christmas came early https://uploads.tapatalk-cdn.com/201...22284b9075.jpghttps://uploads.tapatalk-cdn.com/201...3fd4500949.jpg
sriracha June 18th, 2019 16:04
Haha! A burrito’s worth of downforce is something.
The 4-Motion valance looks 10 hrsprs faster.
Judson June 18th, 2019 17:04
Sriracha - thanks for the update. That area of my front is really beat up. It just clips into the bumper cap, yes?
Nevada_TDI June 18th, 2019 17:08
I am starting the process of replacing my alternator that caught itself on fire.
sriracha June 18th, 2019 18:45
I had removed the front bumper in order to replace the headlights. With the bumper off, it was easy to unclip the lower valance. I had to drill holes in the 4-Motion valance, along the lower trailing edge, in order to attach the rigid lower sheild. I used the old valance as a drilling guide. I laid the 4-Motion valance on the ground, upside down, and put the original on top. Using spring clamps to keep them alligned along the edge and centered (allign the little stiffening ridges) I drilled the holes. The 4-Motion valance clips right in to the bumper and fits exactly the same as the original.
IndigoBlueWagon June 19th, 2019 02:32
I've had a 4-motion valance on my wagon for so long I forgot about it. Rear, too. it fits on '02 Wagon bumpers. On '03 or earlier cars no drilling required
hitman1985 June 19th, 2019 02:38
Originally Posted by BakoTDI (Post 5516266)
This is the mess I was left with:
http://pics.tdiclub.com/data/500/medium/IMG_41631.jpg
Now, what is this plug for?
http://pics.tdiclub.com/data/500/medium/IMG_4166.jpg
I know I have some resoldering and heat shrinking to do here (this was the "PROFESSIONAL'S" work) in order to clean these connections, but hopefully none of this gives me any trouble when I receive my new unit.
Now, what was this blue wire go to?? Definitely got yanked out of somewhere...hoping someone can shine some light on this...thanks guys!
http://pics.tdiclub.com/data/500/medium/IMG_4172.jpghttp://pics.tdiclub.com/data/500/medium/IMG_4168.jpg
Who or what is amplified antenna wire. Unless harness includes aux/remote pwr for amps
Image below is my personal harness setup for the h/u
Why not use a euro style terminal instead of the soldering; may be a safer choice but I'm not sure as far as impact would go on resistance changes
Sent from my SM-G965U using Tapatalk
https://uploads.tapatalk-cdn.com/201...acec12f677.jpg
wonneber June 19th, 2019 07:17
The blue wire seems to go to a power injector for the amplified antenna base our cars have.
It should get power to it.
I added a similar one to mine when I replaced the radio.
hitman1985 June 19th, 2019 07:22
Oh I'm aware I was answering the question for the member
BakoTDI June 19th, 2019 08:00
The blue wire seems to go to a power injector for the amplified antenna base our cars have. It should get power to it. I added a similar one to mine when I replaced the radio.
In other words, I should be looking for the other end of the blue wire somewhere in the dash and reconnecting them?
Powder Hound June 19th, 2019 09:32
... Am I imagining things?
Yes, quite so.
Cheers,
PH
Nuje June 19th, 2019 22:39
What I did....sold it. :(
Had the car for over 12 years, learned a lot, did a lot of "tweaks", it took us on a lot of trips and adventures, but we just weren't driving it very much any more, so it was time to pass it along for its next chapter.
Glad we found a buyer who seems to appreciate it as much as we did.
Page generated in 0.27587 seconds with 8 queries
[Output: 25.46 Kb. compressed to 24.43 Kb. by saving 1.03 Kb. (4.04%)]
