Hello, this is my first post so be easy on me.
I just bought a 2006 jetta 5 speed manual. Has 190,000 miles on it.
I drove it to work just fine yesterday morning but on the way home it lost power in 5th gear going up a small hill. Also, the cruise control stopped working, the light is on but just won't work. I stopped and turned the car off and turned it back on. It seemed to work good but after about 5 minutes of driving, the car lost power again in 4th and 5th gear only. The cc stopped working again as well. This time the check engine light came on. It maintains speed but I can't get any progression or power even at full throttle. I had a guy run a code reader at the auto parts store and he said something about low boost or turbo problems but nothing specifically. I don't know what the specific code was either. So I am curious as to what you all think it could be or if you have had similar problems before. Please help I appreciate it.
I also found this other thread it sounds similar but I thought I would see if there were any other comments to help out. Maybe the N75 valve?...
http://forums.tdiclub.com/showthread.php?t=388145&highlight=check+engine+light+cruise+control
Thanks for any help!
