mbesemann
I know this technically belongs in the Biodiesel forum but since I'm asking it from a mk6 perspective I figured I'd post here.
Has anyone run B5 or even B20 in their CR TDI? Is this a really bad idea considering how finnicky the fuel pump is? I heard that if you do start running biodiesel you should account for a fuel filter change in the next few thousand miles because of all the "guck" the biodisel pulls out.
I have an EGR & DPF deleted car so the blow-by issue should not be a factor.
Thoughts?
Thoughts?
