TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) (http://forums.tdiclub.com/forumdisplay.php?f=94)
-   -   Timing Belt Change (http://forums.tdiclub.com/showthread.php?t=506167)
adjat84th March 22nd, 2020 05:12
Originally Posted by ticaf (Post 5580001)
a few questions:
1. what is the preferred method to support the engine ? (from top or below)
2. it is not very clear how to remove/reinstall the lower belt cover, there is some kind of breakable tab ?
3. the camshaft sprocket central bolt has to be loosened, then retightened using the counterhold spanner. torque spec is 100NM, how easy/hard is it ?
4. to loosened/retorque the high pressure fuel pump sprocket central bolt, is it necessary to counterhold on the camshaft sprocket with the belt on ?
thanks for any input.
1. From above
2. Don't worry about the breakable tab, I had no problem reinstalling. I think it's something to aid in faster engine assembly
3. Use the cam sprocket counterhold tool (TB tool kit)
4. I don't recall having to loosen the CP4 sprocket unless you're pulling the pump for some reason?
ticaf March 22nd, 2020 06:46
Any recommendations for an engine support bar?
adjat84th March 22nd, 2020 06:48
I have a harbor freight unit, has worked well for timing belts and clutch changes.
Nuje March 22nd, 2020 09:14
There's always the beloved Herm-o-hanger:
https://www.dropbox.com/s/pw23hmswvx...nger.png?raw=1
Even comes with its own instructions. :D
https://www.dropbox.com/s/f4xy8zisrf...ions.png?raw=1
ticaf March 22nd, 2020 17:56
where did you rest the support bar ? the available rest points that i can see is too far up from the lift hook ring on the engine.
would something like this work better:
https://www.amazon.com/OEMTOOLS-2495.../dp/B01GGBOQT2
ticaf March 23rd, 2020 21:07
was quoted $1500 by the dealer, but that's without coolant flush I imagine.
So far I'm shopping for parts. The OEM water pump is quite expensive ($400). HEPU seems to have a nice one (P669) for half the price or so.
I figure $400 or so for parts (OEM but not genuine), $250 for tools. and $100 for misc supplies, coolant for flushing, etc.
so we are talking $800 in parts (rounded) and maybe 5 hours of labour (have manual and youtube videos).
what do you guys think ?
adjat84th March 24th, 2020 17:12
The pumps have gone up!
My dealer has one for $345 here
Back when I replaced my fuel pump, I thought I had a small leak coming from the pump and purchased one just in case. Still have it, brand new in box. It may not be the most updated revision though.
As for engine hoist, it works just fine! The one you linked could be great for clutch jobs though.
ticaf March 24th, 2020 19:28
That's a good price. I just ordered the kit from IDPARTS. Will let you guys know how it goes. I also found a claimed new pump on ebay for $59. different part number but looks identical to the OEM one. P/N is 010157801 which is for a Tiguan. could be an old one where there is a different part number for the frame of the pump and the rest. Otherwise, correct part number is 04L121011P for a current new OEM,
740GLE March 25th, 2020 03:29
oh god, stay away from ebay. is it worth 3K to save a couple bucks?
ticaf March 25th, 2020 07:16
Originally Posted by 740gle (Post 5580675)
oh god, stay away from ebay. Is it worth 3k to save a couple bucks?
I agree!!
ticaf March 26th, 2020 07:22
water pump procedure?!?
The manual calls for draining coolant before removing the coolant pump. Then it also details the painful way to fill and bleed the coolant. I still have a headache from reading it (specialized equipment required).
On the videos I found on youtube. people just remove the pump, dumping coolant all over, and then just refill the expansion bowl and call it a day.
Anybody has any experience with that ?
adjat84th March 26th, 2020 07:30
You can try and drain from one of the lower hoses, but you're still gonna get dumped on when removing the pump.
Refilling this car is easy, but takes time. You can run the two auxiliary pumps with VCDS, but in my experience it didn't help much. First fill should be to the brim of the bottle, and you should drive the car to get up to temp (or idle forever). I believe I ended up having to refill the bottle 2 or 3 times and then it was good. Just keep coolant/distilled water with you!
ticaf March 26th, 2020 07:58
did you actually drain from the lower hose (radiator) ?
I'm worried doing so will introduce even more air in the circuit.
adjat84th March 26th, 2020 08:06
I haven't replaced my water pump. Just some other work that resulted in a gallon or two of coolant loss. I am not sure how much more could have been in the system compared to a water pump replacement.
Sent from my Pixel 2 using Tapatalk
bmwM5power March 27th, 2020 11:53
good price? that pump could be had for 260
Page generated in 0.10353 seconds with 8 queries
[Output: 18.97 Kb. compressed to 18.07 Kb. by saving 0.89 Kb. (4.70%)]
