TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   TDI Cars for Sale/Wanted (http://forums.tdiclub.com/forumdisplay.php?f=51)
-   -   B5.5 Passat TDI GLS Wagon w/ Manual Transmission (http://forums.tdiclub.com/showthread.php?t=488201)
sindromedeloeffler April 15th, 2018 22:08
In a seemingly endless scrap heap of poorly maintained B5 or B5.5s, this is the diamond in the rough. 100% North Carolina history. Long history of 505.01 spec oil changes and manufacturer recommended timing belt interval changes with OEM parts
"Arguably the most beautiful Station Wagon built in the past 40 years"
The inherent problems have been addressed by a VW certified master tech: chain driven balance shaft trash removed before its imminent failure and replaced with OEM gear driven part VW put in later european PD TDIs. Auto tragic removed before failure replaced with a euro only code FHN 5-speed manual transmission, imported from the Netherlands ensuring proper Diesel gear ratio with single mass RS6 clutch ready for more power if you so choose.
Malone stage 2 tune
"these 2 fixes might very well deem this car bombproof"
EGR delete
Approximately 180k with a whole lot more left to go.
Exterior: properly maintained non fading intact clear coat on VW black, tinted windows, high gloss black 3m wrap on all exposed chrome.
Interior: Above average condition Beige interior with monster mats
Sunroof w/o leaks
Electrical all works correctly
Fun stuff:
W8 OEM HID with 6000k phillips light with halogen brights, VW OEM rheastat switch to control light leveling
custom HID fogs with 3000k light
All other bulbs switched out for properly resisted LEDs to ensure proper functionality
ST coil-overs with adjustable control arms for proper alignment and thick THOR aluminum belly pan to protect
19 inch 5 arm hook end wheels from a 2013 Q5, wrapped with life 235-35r19 continental extreme contact DWSs
Pics to come, if I can figure out how, little help?
$15,000
oilhammer April 16th, 2018 11:05
Wowzers.....
RexNICO April 16th, 2018 11:14
Originally Posted by sindromedeloeffler (Post 5399707)
Pics to come, if I can figure out how, little help? ...
Though most forum software interfaces would lead you to believe you can "attach" images (or even files) those features are typically disabled.
To post pics you'll need to have them hosted online (TDIClub has a photos link to a gallery) and then link the images (either as links or embedded).
Hope this helps.
JDSwan87 April 16th, 2018 11:31
Malone stage 2 tune
EGR delete
Sunroof w/o leaks
Fun stuff:
$15,000
Curious what this sells for...
aja8888 April 16th, 2018 11:33
$15,000
You're kidding, right? :confused:
If not, GLWS.
oilhammer April 16th, 2018 12:23
Me too.
johnboy00 April 16th, 2018 12:59
"Bombproof"? Has the cam been replaced?
mogly April 17th, 2018 05:42
Personally owning a couple B5.5s and one of them a wagon almost exactly to this spec I'm rooting for the seller!!
JBjunior April 17th, 2018 16:43
I am pretty sure the other one that was priced similarly recently is either still for sale or was withdrawn....
bbexotics April 17th, 2018 17:41
Wozzer!!!good luck!!!!!
tikal April 17th, 2018 23:32
Mama mia!
aja8888 April 18th, 2018 11:18
Originally Posted by tikal (Post 5400341)
Mama mia!
Quick, sell yours while the flames are burning hot! :D
tikal April 18th, 2018 21:28
I would feel 'naked' without my B5.5 wagon :(
oilhammer April 19th, 2018 04:25
Me too... and mine is cursed with spark plugs.
truman April 19th, 2018 17:09
I still like mine a lot.
Original tranny at 245k.
What else is comparable?
Page generated in 0.07375 seconds with 8 queries
[Output: 16.06 Kb. compressed to 15.16 Kb. by saving 0.91 Kb. (5.64%)]
