brumbar
Hi everybody! I have been reading this forum 2-3 months. This is my first post. Here is the story: Friend of mine has a repair shop for Commercial Trucks like Freightliner, Kenworth, Peterbilt and etc. He also has a VW Passat 2.0 TDI-PD, I'm not sure what year, but the engine is PD - 100% sure! He is so busy with the shop and never thought that the TDI-PD required some special oil. He used only Shell Rotella T 5W40 synthetic for 130 000 miles!!! Because this oil is the main he uses for the Big Trucks and probably, he is getting it for a very good price. Oil and oil filter changes are done every 5000 miles, Fuel filter every 10 000 miles (The same pump-duse technology is used in commercial trucks, in order injectors to last almost 1 000 000 miles, you must change the fuel filters often, BTW big trucks have 2 fuel filters - the housing of one is clear glass, so you can see the condition.)
Anyway the motor is running excellent, he recently changed timing belt, pulley and water pump. When I told him for the special oil required for the PD engine, first he panic a little bit, but after he said: The commercial diesels using the same technology are running 800 000 miles with rotella T with no problems, if this oil is wrong the engine wouldn't pass 50 000 miles.
I will be very pleased to hear your comments on this one.
