TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   TDI 101 (http://forums.tdiclub.com/forumdisplay.php?f=43)
-   -   92 jetta possible injection pump problems (http://forums.tdiclub.com/showthread.php?t=486465)
92jettatdifan February 17th, 2018 19:47
hey i have a 92 jetta 1.6 tdi with a little over 400 000 km on it and im haveing problem with it cutting out when driving as if its not getting fuel injection pump has a small leak around the throttle not sure if its related but its not consistant it can be driving well and all of a sudden it falls on its face and wont run past quarter peddle makeing it very difficult to drive theres no air on the inline so im courious if it would be do to the pump and if i can find a guide to rebuild it i would really appreciate any input on this problem
Vince Waldon February 17th, 2018 20:37
Your 1992 is an IDI engine, as opposed to a TDI. InDirect Injection, 100% mechanical, no computer. :)
As such, I'd recommend posting over at www.vwdiesels.net... that's where most of the IDI folks hang out these days and you might get some good ideas.
Some folks here may be able to help as well, but this is primarily a TDI site. There is an "other diesels" forum section here where IDI engines get discussed.
Your leak at the throttle shaft is fairly common on a car this old and not too hard to fix... there will be some good threads over there on this as well.
That said, it's probably not causing your sudden loss of power.
Prairieview February 18th, 2018 01:36
1) have you changed fuel filter this century?
2) is there still a plastic water separator located on the bottom of the car below the passenger-rear seat area? If so, remove it and throw it away and simply splice the two lines together instead of having the old fuel separator which, over time, cracks and allows air to be drawn into the line.
3) have you ever pulled the fuel sender unit out of the top of the fuel tank and cleaned the little screen?
Just some of the "usual" crap on the older cars.
Page generated in 0.06536 seconds with 8 queries
[Output: 5.36 Kb. compressed to 5.20 Kb. by saving 0.16 Kb. (3.02%)]
