TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) (http://forums.tdiclub.com/forumdisplay.php?f=81)
-   -   changing oil in a 2010 tdi golf sport wagon (http://forums.tdiclub.com/showthread.php?t=288563)
vwmg57 July 22nd, 2010 06:33
I have a 2010 golf tdi sport wagon and want to change my own oil. I guess I have to get the oil from VW and that is ok but who do I get or how can I get the service interval display reset.
:confused:
JSWTDI09 July 22nd, 2010 09:02
:confused:
I suggest learning how to use the search function. I found this in about 5 seconds by doing an advanced search and searching for "reset + service"
http://forums.tdiclub.com/showthread.php?t=286382
Have Fun!
Don
vwmg57 July 22nd, 2010 09:31
Thanks for the info Don. I have a 2010 and the information you gave me is for an 06
LITTLE-LARRY July 22nd, 2010 12:23
Read the post that Don linked for you.
LARRY
JSWTDI09 July 22nd, 2010 12:32
I think it will work on a 2010, I know it works on a 2009. It can't hurt to try it. Let me know if it doesn't work. I have the service manual at home, so I can check when I get home from work tonight.
Have Fun!
Don
panzer July 22nd, 2010 16:47
vwmg57
The easiest way to figure out how to reset the service interval display is to read the owner's manual. It should be located in thesection that describes how all the other display and controls work.
As far as the oil change, someone with access to the Bently or Alldata will have to answer that.
Good luck!
Elfnmagik July 23rd, 2010 06:59
Get the Mobil M1 ESP 507 @ Pep Boys.
JSWTDI09 July 23rd, 2010 09:05
Unfortunately, the OP is from Canada and there are no PepBoys in Canada. However he should be able to find Mobil One ESP in Chrysler/Dodge dealers for use in CRD Sprinters.
Have Fun!
Don
Page generated in 0.06675 seconds with 8 queries
[Output: 9.50 Kb. compressed to 8.93 Kb. by saving 0.57 Kb. (5.97%)]
